Wiring
Old Apr 18, 2007 | 12:40 PM
PReal's Avatar
PReal
Default RE: Wiring
Guilty as charged..... LOL
It is really quite simple though.
Old Oct 5, 2007 | 04:49 PM
Doomtroop's Avatar
Doomtroop
Default RE: Wiring
ORIGINAL: PReal
Its quite simply due to the magnetic field a pulse of electical current creates. The magnetic field induces changes in most low voltage wires within the magnetic field the pulse created, sort of like an eddy current. The voltage difference also plays a key role. You can run power wire next to speaker wire all day because they are both high voltage and high voltage can resist the changes. Running a power wire next to a signal wire is bad because the low voltage in the signal wire is easily manipulated. A speaker wire and a signal wire will have little to no reaction because even thought the speaker wire is high voltage the current pulses are not high enough to create a strong enough magnetic field to induce interference.
Thats at least what my engineering degree has led me to beleive. I am one of the engineers that canusuallyapply thier learnings to everyday life, but sometimes I still nerd out.
Thanks for the explanation. Now I really understand how this works...
jwog666
Dec 27, 2021 08:09 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
lmurf60
Sep 24, 2015 10:07 PM
