annoying!!!!!!
Old Apr 28, 2007 | 04:58 PM
eddiev22's Avatar
eddiev22
Default annoying!!!!!!
okay, so i took my stock head unit out and in the back wiring harness, i wired the remote turn on to the gray blue/white wire, the subs hit fine for the first 10 seconds then die out... wtf!? i have no idea what to do, i called ford and they said try wiring it to a wire that didnt work.. is it a bad remote wire ? but when i would touch the remote wire to the power it would work fine, (12v was going through it)
Old Apr 29, 2007 | 10:52 AM
ttocs's Avatar
ttocs
Default RE: annoying!!!!!!
I thinkwe told you before, the blue/white wire was if you were hooking up to an aftermarket deck. I do not know the stock wire color as anytime I needed to find it I used a voltmeter as should be done to confirm the wire is correct before wiring into it.
Old Apr 29, 2007 | 05:44 PM
eddiev22's Avatar
eddiev22
found it.. its black/pink if anyone else is wondering
drfister
May 3, 2018 10:38 PM
SSG Steggy
3.7L V6 Technical Discussions
Nov 5, 2015 03:09 PM
tmdm
Sep 4, 2015 06:45 PM
gus_vb
Aug 29, 2015 11:35 PM
kdryan
Aug 21, 2015 09:47 PM
