CDs Stuck AGAIN!
Old May 17, 2007 | 02:09 PM
01MustangGirl's Avatar
01MustangGirl
Default CDs Stuck AGAIN!
I know this has been posted about before, and I have had all the same issues as everyone else with the 460 in my '01. But this morning it took another turn... went to eject CD2 (there was a CD in there) and it said no CD, while I was trying to help it out with another CD, and it took that one... So now I have 7 CDs in a 6 CD player. Am I am completely screwed?! Will disconnecting the battery work in this case also?
Thanks for your advice in advanced!
Old May 18, 2007 | 03:58 PM
PReal's Avatar
PReal
Default RE: CDs Stuck AGAIN!
Those 6 disk units fail like crazy. You should buy an aftermarket unit and then tear into the 6 disc to recover your CD's.
Old May 18, 2007 | 07:10 PM
AFlanders's Avatar
AFlanders
try ejecting again and grab the cd and pull it out.
Mine said the same thing "no cd" so i turned the car off and then on again, it started to eject but then wouldn't, so i grabbed on to it(abouta cm)and yanked it out.
If that fails pop the head unit out and dig for it.lol Good luck bro
Old May 20, 2007 | 05:33 PM
01MustangGirl
Thanks for your advice! I went ahead and have tried several times--turning the car off and on. That has worked in the past. I even tried disconnecting the battery, still did not work. I think I have to have someone look at it. When I try to eject a cd it doesn't even make any sounds like it is try to do something.
Old May 22, 2007 | 07:27 AM
DarkShadowGT03's Avatar
DarkShadowGT03
Try smacking down on your dash as you try to eject it lol...usually works for me.
mrtrodonet
Sep 19, 2020 03:12 PM
DreadPirateRoberts
Sep 26, 2015 02:11 PM
jstrothe
Sep 24, 2015 12:17 PM
rafotree
Sep 22, 2015 03:55 PM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
