Multiple Size Subs Setups
Old Jun 20, 2007 | 10:13 PM
The_Third's Avatar
The_Third
Default Multiple Size Subs Setups
Why is it that most of the community is against having subs of different sizes? As I understand it, cross overs or wiring can be a problem? I figure that if you combine smaller subs with larger subs, you'll have a system that hits hard, quick, and can hit highs and lows effectively. Obviously your speakers would have to be pretty loud to compensate. Is it still a problem if you amplify each sub/each respective size separately? Thanks
Old Jun 21, 2007 | 02:27 AM
Melectrok's Avatar
Melectrok
Default RE: Multiple Size Subs Setups
You just have to make sure the diffrent size subs dont share an enclosure unless it has a seperator or it defeats the purpose. Multiple sizes has great fill. You will prolly need seperate amps for each though to do it correctly
Old Jun 21, 2007 | 02:16 PM
Hisss04Cobra's Avatar
Hisss04Cobra
says hiththth
Ok brother.
Aten inch driver does not soundtigher than a fifteen inch driver.
Vice versa, a fifteen inch driver does not always slam lower notes than a ten inch driver.
It is all in the box design.
Go back to car audio 101, i.e. the sticky, and then come back and talk to us.
Old Jun 21, 2007 | 02:49 PM
850SN95's Avatar
850SN95
so a 12 inch sub and a 8 inch sub wouldnt sound awesome?
Old Jun 21, 2007 | 02:56 PM
Hisss04Cobra
says hiththth
ORIGINAL: 850SN95
You have got to be more in depth than that.
Old Jun 21, 2007 | 05:23 PM
seight311's Avatar
seight311
Yes, thats very vague.
I mean yeah you can do say a 15", 12", 10" and an8". But it's a waste of time and money, the notes the 8" excells in that the 15" shouldn't play, wont be loud enough to over come the bass the 15" is still putting out.
It's like shooting a guy with a .50 cal and then topping it off by shooting a slingshot at him. It's a lost cause.
Biggest thing for sure. Thats why you can take a 6" woofer and put it in the right box and it will be as loud as a crappy 12" in a crappy box.
Old Jun 26, 2007 | 08:13 PM
Nazar's Avatar
Nazar
Not to mention you will have cancellation isuues in the trunk. The bigger sub will definitely overpower the smaller.
For example you want to do 2x12 and 2x8 you are better of doing 4x10"
You want all your subs hitting the same way.
Hope this shelps.
Old Jun 26, 2007 | 09:12 PM
The_Third's Avatar
The_Third
I never thought of it that way, thanks!
Old Jun 28, 2007 | 07:24 PM
850SN95's Avatar
850SN95
im not putting a 12" and a 8" sub in my car it was just something i thought i'd ask.
uberstang1
Sep 20, 2015 06:42 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
