amp problems
Old Jul 1, 2007 | 11:04 PM
enix187's Avatar
enix187
Default amp problems
8 guage power to 600w xplod 4channel, had 2 channels going to a pair of 120w max xplod 6x9's and bridged to a bazooka 8"
Ive had the system in for a while and it has worked fine for a while but after i put the new carpet in i can't pay it to work.
it started with a vibrating noise that came from the 6x9's when the bass would hit and after i rewired the connections the amp check light won't even come on, checked all fuses, sterio works fine just runnin on speaker (unhooked amp)
the only thing that changed between the carpet is the ground moved from between seat post and bair floor to a screw and washer on the floor
Old Jul 2, 2007 | 12:03 AM
seight311's Avatar
seight311
Default RE: amp problems
amp problems
You answered your own question pretty much.
Your speakers are damaged, or blown.
Old Jul 2, 2007 | 01:26 AM
enix187's Avatar
enix187
600w MAX output, 120 rms, power at half for speakers,
i said they work fine just on head unit power
Old Jul 2, 2007 | 12:50 PM
seight311's Avatar
seight311
Move your ground, make sure theres no paint, you want bare metal, use a razor, sand paper or brillo pad to remove anything from your ground area.
Old Jul 10, 2007 | 11:33 AM
nofear45465's Avatar
nofear45465
the problem is that its sony.
Old Jul 10, 2007 | 03:43 PM
PReal's Avatar
PReal
The power at half still is more then likely way to much for some sony 6x9's! Especially if you are using a full range driver as a bass source.
vbonina
Sep 22, 2015 08:31 AM
daytooday
Sep 20, 2015 10:55 AM
Art161
Sep 9, 2015 10:33 AM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
