quick audio upgrade HELP
Old Jul 21, 2007 | 12:41 PM
  #51
laserred38's Avatar
laserred38
Default RE: quick audio upgrade HELP
[unsubscribes from thread...]
Old Jul 21, 2007 | 12:42 PM
  #52
laserred38's Avatar
laserred38
Dude it is a SHOP. Not a shope...
Old Jul 21, 2007 | 02:55 PM
  #53
sandcracker21's Avatar
sandcracker21
ok??? i didnt think i typed shope but alright....
well i get more and more confused as i continue to try and get an rca connection to the stock HU, as EVERYONE is telling me something different....now im hearning that its almost impossible and that i should tap into the "data cable" in the rear??? im such a noob here that i cant figure out what to do...
once again i have everythign else hooked up by the previous setup....bat. cable. ground wire. and turn on wire(installed into HU) is all in place already
all i need now in the signal!
NOTE: the amp has high level inputs what ever that means
Old Jul 21, 2007 | 05:13 PM
  #54
PReal's Avatar
PReal
If the amp has high level inputs then just splice into your rear speaker wires if you want to do it the easy way.
Usually low level inputs will allow for better sound quality, but I don't think you're too worried.
Old Jul 21, 2007 | 05:24 PM
  #55
sandcracker21
will this not cause a power shortage for my speakers? sorry for allt he questions, im an electrical virgin
Old Jul 21, 2007 | 05:46 PM
  #56
seight311's Avatar
seight311
It's a high level input, it's going to sound like crap.
Once again, use the high level input on your amp it's pretty self explanitory, you have the piece that plugs into your amp and it has wires sticking out of it and you run that up to the speakers your tapping into and splice and connect them.
Or do it the right way, remove your door trim things and pull your cd player out plug in the RCA's to your deck route the RCA's to the trunk and plug them into the amp. This is so simple, im confused as to why this seems so difficult to you.
Old Jul 21, 2007 | 05:47 PM
  #57
seight311's Avatar
seight311
ORIGINAL: sandcracker21
And if you want tap into your rear speakers and disconnect them at the same time, rear speakers are pointless anyway. Problem solved, no "power shortage" worries for you
Old Jul 21, 2007 | 05:59 PM
  #58
sandcracker21
i have located a write up on mustang world.com how to do this....is that what your talking about? as for disconnecting the rear speakers i dont really want to do that....although i see your point of the noice coming from behind being secondary, but still
if i follow this write up will i be fine? im scared of f'n sumthing up bad
Old Jul 21, 2007 | 07:45 PM
  #59
seight311's Avatar
seight311
But still what? There is nothing you can say thats good about your rear speakers that wont be better if you take them out. You cant even begin to create an argument about having rear speakers unless you have 5.1 in your car, which you do not and will not have in your car.
I dont know what "write up" your referring to. Those 2 sentences I typed up, thats how you do it. Thats it, yes thats it. Thats everything, it's so simple, you want it to be harder than it is, thats your problem. You think this should be some big project.
Your acting like changing your wiper blades is a motor rebuild. It's simple, it's so simple.
Stop making this hard. Your going to lose hair over this if you keep thinking so hard.
It's simple, it's simple, it's so simple.
Thats all you have to do, thats it. That is it. Those 2 sentences I typed. Thats everything! EVERYTHING! Thats all!
Go do it.
Did you catch on to what im saying?
it's simple, thats it.
Old Jul 21, 2007 | 08:33 PM
  #60
sandcracker21
ORIGINAL: seight311
the mach460 HU does not have rca jacks
