Viper 771XV Remote Start
Old Dec 8, 2007 | 12:14 PM
95stang5.0's Avatar
95stang5.0
Default Viper 771XV Remote Start
Hello I have the Viper 771xv installed on my car. Its the alarm/remote start. I am doing an auto to t-5 swap and wanderd what i would need to do to unhook, or by bass the park saftey switch for this. I woldnt be to heart broken if i could just disconnect it because i never use it.
Old Dec 8, 2007 | 01:44 PM
ttocs's Avatar
ttocs
Default RE: Viper 771XV Remote Start
you are wanting to disable the remote start portion, or disable the safety start on the car?
Old Dec 9, 2007 | 10:26 AM
95stang5.0's Avatar
95stang5.0
It really doesnt matter. Which ever is easiest. If i can do it for free rather than paying someone to do it. Id go that route. What do you think.
Old Dec 9, 2007 | 06:18 PM
ttocs's Avatar
ttocs
let me word this a different way.
are you wanting to disable the remote start so that it will not work anymore?Or are you wanting to disable the safety start so that it will crank while in gear? They are two different things.
Old Dec 9, 2007 | 09:33 PM
95stang5.0's Avatar
95stang5.0
id rather just disable it to be on the safe side. Or if the way it is setup now will work when i take the auto out and put the manual in along with a manual computer will work then thats fine too. And the remote doesnt have to work just so the car turns over regularly with the key.
Old Dec 10, 2007 | 10:49 AM
Dave5point0's Avatar
Dave5point0
If your t-5 swap is done correctly then the car shouldn't be able to crank without the clutch pushed in, so you shouldn't have a worry there.
But if you want to disable the remote start so you have absolutely NO way to have the car accidently remote start, then look at the wires going into the alarm brain, and there will be a black wire with a white stripe in a 5 pin wire harness, cut that wire and the remote start function is disabled but the rest of your alarm will still work just like before.
Old Dec 10, 2007 | 10:12 PM
ttocs's Avatar
ttocs
wut he said
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
1TUFF302
Nov 5, 2015 04:02 PM
StalkerGT
Sep 25, 2015 02:41 PM
dalefrancis88
Sep 11, 2015 07:15 AM
5.0 kevo
Sep 3, 2015 06:24 PM
