Amp Problem
Old Jan 26, 2008 | 10:30 PM
JGor10's Avatar
JGor10
Default Amp Problem
Okay, I have two 12' alpine woofers and im trying to hook them up to my 300 watt amp. I have it powered, grounded, and the remote wire hooked up. And the light on the amp is coming on, so I guess I'm getting power. I tested the connections running to the amp which fine but the speaker output connections were dead! Is the amp shot or am I doing something wrong?
Kind of new to trouble shooting but have hooked up sytems in the past. Help would be appreciated!!
Old Jan 26, 2008 | 11:23 PM
Spyder's Avatar
Spyder
Default RE: Amp Problem
2 12" to a 300W amp...
Can you specify what amp, what subs, and how you connected the subs to the amp?
ttocs, are your ready for another impedance discussion?
Old Jan 26, 2008 | 11:35 PM
JGor10's Avatar
JGor10
The amp is a pyramid 4 channel 300 watt. I have a box with the two 12' woofers in it but it has one output for the speakers.
Old Jan 26, 2008 | 11:47 PM
JGor10's Avatar
JGor10
Ha nvm! I just found out what kind of rep pyramid has. This amp was given to me so I cant beat that but now I know why. I'll just invest in a better quality amp. Im pretty sure its the amp and not my setup. Thanks for trying to help spyder!
Old Jan 27, 2008 | 11:46 AM
ttocs's Avatar
ttocs
the problem probably has to do with you runing a 4 channel amp in a wierd, mono mode that it is not designed to work under. You might be safe bridging it to a 2 channel mode and then to the subs, you will need to make a hole in the box to run the wire through then.
Old Jan 27, 2008 | 06:59 PM
Spyder's Avatar
Spyder
ORIGINAL: JGor10
Haven't we all had a 1000W Pyramid amp at some point in our lives?
Good call on getting a new amp.
JGor10,
Read up on two things before buying a new amplifier.
1) The difference between an Amps Peak power rating, and its RMS power rating.
2) How to wire multiple subs with a single amplifier.
Normally I'd post links and resources, but I'm short on time today.
Read up on those topics, and post back here if you have any questions.
vbonina
Sep 22, 2015 08:31 AM
daytooday
Sep 20, 2015 10:55 AM
Art161
Sep 9, 2015 10:33 AM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
