Door Panel to 2005 Mustang
Old Mar 9, 2008 | 01:47 PM
Gordon24's Avatar
Gordon24
Default Door Panel to 2005 Mustang
How do I get the door panels off? I've taken out every screw I see but I still cant get it off.
[/align]
Old Mar 9, 2008 | 02:22 PM
Shock521's Avatar
Shock521
Default RE: Door Panel to 2005 Mustang
door panel removal.pdf
there are a few hidden screws that you probably missed.
Old Mar 9, 2008 | 03:18 PM
CrazyHorse0217's Avatar
CrazyHorse0217
This will come in handy when I sound deaden my doors next weekend.
Old Mar 11, 2008 | 11:20 PM
lundis's Avatar
lundis
first, remove sail panels (behind side mirrors)
then pry off plastic cover behind latch handle, and remove torx srew (t-30)
then pry off plastic cover behind pull handle, and remove another t-30 torx.
pry up window switch panel, and pull housing out towards you. a bolt is behind that. i think it was 7mm.
then there are about 5-6 7mm bolts around the circumference of the panel. pull up, and down.
if you need any help, beyond this, email me @ boomincavvy@gmail.com i get it on my blackberry.
Jgabbard
May 8, 2018 03:37 AM
WDScott
Aug 17, 2015 06:38 AM
'stangdude
Aug 12, 2015 01:27 PM
daytooday
Aug 11, 2015 09:22 AM
ericunderwood
Aug 11, 2015 03:40 AM
