What gauge is speed sensor wire?
Old Nov 3, 2008 | 07:06 AM
luvrbcs's Avatar
luvrbcs
Default What gauge is speed sensor wire?
Does anyone know what gauge the speed sensor wire is in a 2007? I want to be sure I use the right tap size. Also, what would I do if the wires (both the tapper and tappee) are different gauges?
Old Nov 3, 2008 | 12:32 PM
ttocs's Avatar
ttocs
if you don't know how to splice wires of different gauges then I don't know if I would recommend doing anything security related....
all the wires you are looking for will be small. The only wires that are of any thickness are the ignition wires.
Old Nov 4, 2008 | 07:26 AM
luvrbcs's Avatar
luvrbcs
Maybe I explained it wrong. I know how to splice.
I want to use the correct t-tap for my connection. I think the VSS wire from the unit (AVIC-D3) is either 14 or 16 ga. I am thinking the VSS wire in the car is larger.
I used a red t-tap to hook it up and I am getting an intermittent pulse on the nav unit. So I am thinking I don't have a good connection. I probably should have went with a blue t-tap but I am also wondering if I can use the blue for the smaller gauge wire of the nav unit.
For anyone with an AVIC D3 who hooked up their VSS, what t-tap did you use?
Old Nov 4, 2008 | 03:59 PM
ttocs's Avatar
ttocs
I have been installing for well over 10 yrs and never had a bad T-tapp connection.
I have been installing for well over 10 yrs and I have never used a T-tapp connection.
I plan on keeping this record perfect for well over another 10 yrs. T-tapps have absolutely NO use in car audio and security unless you like diagnosing bad connections.
ABSOLUTELY NO USE.................
Old Nov 4, 2008 | 05:57 PM
luvrbcs's Avatar
luvrbcs
Wow. I don't know what to say...
Old Nov 4, 2008 | 08:11 PM
ttocs's Avatar
ttocs
if you suspect a bad connection from a t-tap there is only 2 ways to test it. Jiggle the wire at the connection, or replace the connection with a proper connection. T-taps are just not a solid connection when placed in a situation where it is exposed to vibration.
Solder connections are always prefered, crimps are almost always acceptable, but t-taps just have no place in a car.
Old Nov 5, 2008 | 12:03 PM
luvrbcs's Avatar
luvrbcs
Still wondering what gauge the VSS wire is.
Anyone?
Old Nov 5, 2008 | 12:27 PM
ttocs's Avatar
ttocs
redgt04 would be better to ask. he has not been on here for a few days you might need to send a pm.
Old Nov 5, 2008 | 01:41 PM
luvrbcs's Avatar
luvrbcs
Thanks.
articman
Jun 21, 2018 11:45 PM
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
