back to the basics
Old Feb 12, 2009 | 12:50 PM
IanJK46conv's Avatar
IanJK46conv
Default back to the basics
http://www.caraudiomag.com/testrepor...ier/index.html
This is the amp I am going to use in my commute car. I would like to power a single 12" Xplod. These were just sitting around my house collecting dust. They're from my first vehical 8 years ago. When I had them hooked up, I had two subs but now I only have one. Can someone give me some advice how to hook these babies up? How do I determine the frequency and db level? In the site above, it shows some different connections and filters. For instance, which to terminals do I hook my RCA cables?
Below are the stats to my ancient boomer. Help is greatly appreciated.
Product MPN
MPN xsl1235
Key Features
Car Speaker Type Component
Elements 1-Way
Car Speaker Function Subwoofer
Size 12"
Nominal Power Handling 200 Watt RMS
Powered Non-Powered
Technical Features
Peak Power Handling 800 Watt
Frequency Response 25 Hz - 2 kHz
Sensitivity 89 dB
Components
Woofer Material Poly / Plastic
Surround Material Santroprene
Mounting
Enclosure Non-Enclosed
Top Mounting Depth 5.31 In.
Bottom Mounting Depth 5.81 In.
Mounting Diameter / Length 11.31 In.
Old Feb 15, 2009 | 08:58 PM
Bone32's Avatar
Bone32
If you only plan on running one sub your best bet would be to bridge the amp. That simply means running the positive from 1 channel of the amp, and the negative of the other channel of the amp, into the terminals on the sub.
Also, your RCAs are the red and white plug ins. They will run from the back of the head unit into the amp itself.
Any more questions feel free to PM me and i'll be glad to help.
drfister
May 3, 2018 10:38 PM
musnicki
Sep 23, 2015 07:11 AM
Cavedawg
Sep 17, 2015 09:51 AM
spamedic
Sep 9, 2015 12:15 AM
