98 Stang Battery Drain
Old Mar 29, 2009 | 06:25 PM
BiohazardJoker's Avatar
BiohazardJoker
Post 98 Stang Battery Drain
I've got an issue with a power drain. Checked my grounds, etc... I've got a 1.0 cap and 2400 watt amp (2 1200watt 12" subs) and a 300 watt amp (2 6 inch mini subs). Double and triple checked wiring and the battery will be dead in around 8 hours. The Cap shuts off after 2 minutes like it's supposed too. Any ideas??
Old Mar 30, 2009 | 10:50 PM
flood41's Avatar
flood41
does your amps stay on all of the time
Old Mar 31, 2009 | 01:37 PM
BiohazardJoker
Default answer
No, wired to remote antenna, off stock stereo. double checked does not stay on after car is off. the cap will stay on for about 2 minutes after shut off, but that's it...
Old Mar 31, 2009 | 02:09 PM
GTRedfire03's Avatar
GTRedfire03
Pull the fuse on the power wire see if it still goes dead.....if it still goes dead then it not your amp. It is something else in the car.
Battery new or old, have you had the battery check out?
Old Mar 31, 2009 | 07:23 PM
BiohazardJoker
Default answers
battery is about a year old, last one had a dead cell. And the amp goes dead if the fuse is out, if i pull the mater power fuse for amp and cap, the battery doesn't go dead.. Wondering if the Cap is screwy..
BOB ROME
Jul 26, 2023 01:54 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
jerrytubes
Oct 23, 2015 12:11 PM
Bokeo
Oct 10, 2015 08:28 PM
wraith777
Sep 28, 2015 10:49 AM
