Subs and Amp
Old May 16, 2009 | 02:49 AM
g_unotkiller's Avatar
g_unotkiller
Default Subs and Amp
I have a Kenwood KAC-7201 800w amp and 2 Rockford Fosgate 10" p2's, does my amp have enough juice to power the subs or do i have enough power or too much? Dont want to mess anything up.
Old May 19, 2009 | 10:50 AM
JayMax03's Avatar
JayMax03
no actually its ok its not equally matched off but its enough. you have a 2 channel amp thats 230x2 @ 2 ohms and the subs are 250 watts a piece thats if you have wired at 2 ohms
Old May 20, 2009 | 08:12 AM
GTRedfire03's Avatar
GTRedfire03
Amp specs:
PerformanceRMS Power Output (Watts x Channels)150 x 2
Peak Power Output (Watts x Channels)800 x 1Power at 2 Ohms (Watts x Channels)230 x 2Bridged Power (Watts x Channels)460 x 1Minimum Impedance Bridged4Minimum Impedance Unbridged2Best Frequency Response5-50k HzTHD at Rated RMS Power0.08%Signal to Noise Ratio100 dBInput Voltage14.4vFeaturesAmplifier ClassAB Low-Pass Crossover Frequency50-200 Hz Low-Pass Slope (dB/octave)18 dB High-Pass Crossover Frequency150 HzHigh-Pass Slope (dB/octave)12 dB Bass Boost12 dB Bass Boost Frequency90 HzFan CooledYesFuse Rating30 x 2Speaker Level InputsYesPreamp Outputs1 pairLED Power IndicatorYesWidth (inches)13-5/8Height (inches)2-5/16Depth (inches)11-1/4Parts Warranty1 YearLabor Warranty1 Year
Are the P2s dual voice or single? Bc that will matter on how you wire them up, which then we can tell you for the amp spec what type of power you will get from that amp......Just a side note the power rating on this amp is test with 14.4 volt.
Old May 20, 2009 | 12:10 PM
JayMax03's Avatar
JayMax03
whoops guess I should have specified it a little bit more...
breaking
Oct 2, 2015 01:27 PM
Sixer4Life
Sep 29, 2015 07:03 PM
daytooday
Sep 20, 2015 10:55 AM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
