Amp Problems
Old Sep 9, 2009 | 04:54 PM
Graeli's Avatar
Graeli
Default Amp Problems
Ok, I have my amp wired up and everything worked perfect except for I had a rather crappy ground wire so I replaced it yesterday and it worked fine for a while...but then it randomly cut out last night and I can't get the amp to come back on at all. I've undid the ground wire and plugged it back in, moved it around and tried other spots but it still doesn't work. Anyone know what the problem is or how I might could fix it?
Old Sep 9, 2009 | 05:39 PM
Fink's Avatar
Fink
Check all your fuses. Should be one on the power wire and 1 or 2 on the amp itself. Also check your remote wire, make sure that is connected to the HU and amp.
Old Sep 10, 2009 | 12:42 AM
ttocs's Avatar
ttocs
wow man you gotta give us something to work with before we could even attempt to help you.............
Old Sep 13, 2009 | 04:12 PM
mdiak47's Avatar
mdiak47
Check the fuses
Old Sep 16, 2009 | 10:42 AM
JayMax03's Avatar
JayMax03
or you can check the remote wire
vbonina
Sep 22, 2015 08:31 AM
daytooday
Sep 20, 2015 10:55 AM
Art161
Sep 9, 2015 10:33 AM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
