mach 460 headunit replacement
Old Nov 14, 2009 | 07:14 PM
gatorsax02's Avatar
gatorsax02
Default mach 460 headunit replacement
i was just wondering if i installed an aftermarket headunit if the sound quality would be any better...and also is there any special things i would need to install it?
Thanks
Old Nov 15, 2009 | 01:22 PM
ttocs's Avatar
ttocs
there are some special steps that are needed to be done but it depends on what deck you get, its outputs and what you want to do with the system later. Are you going to add additional amps/subs and speakers or just rock the stock speakers? With a little tweeking you can get the mach system to sound even better with a good aftermarket deck then it does with the factory radio.
Page 2 of my cardomain page shows how I put an alpine cd player in my 94. The system has since been completely changed but I can get you through it.
Old Nov 15, 2009 | 04:53 PM
gatorsax02's Avatar
gatorsax02
for now im just gonna get the headunit...later on i might get new speakers...is there anything special i need to know about them?
Old Nov 21, 2009 | 05:08 AM
GTVert2000's Avatar
GTVert2000
i have a 2000 as well, and just recently installed a new headunit, the old one went out on me and ford said they would have to send it out (some rediculous process). so i went with an aftermarket piece. You will need an "amplifier integration harness," and a headunit that has at least 2 a/v outputs with it (for front and rear channels). The harness plugs into these outputs and then plugs into the factory amp lines with the same adaptor. I didnt have to splice into any of my factory wiring or anything, installation was very simple too. Go to www.crutchfield.com they gave me the adaptor and installation kit included with the h/u. Theres also alot of support on their site too which helped me decide what i wanted. Good luck.
Old Nov 28, 2009 | 09:33 AM
cooperm's Avatar
cooperm
Do you have a drawing or instructions on how to do this. I was looking at a HU and it was a 4 channel. Would I still only need the two RCA outputs? Also how do I know which wires the RCA connections go to?
Thanks,
Mark
5.0muscle
Jan 11, 2016 01:17 PM
9550
Oct 26, 2015 05:01 PM
MusicCity615
Sep 12, 2015 07:05 AM
TimeLord101
Sep 4, 2015 09:27 AM
iamgobono
Sep 3, 2015 12:37 PM
