Changing out head unit
Old Dec 1, 2009 | 12:38 PM
SwishSkater's Avatar
SwishSkater
Default Changing out head unit
I want to change my girlfriend's head unit out in her 99' v6 vert. She currently has the base system with the cassette and cd, single din, respectively. What parts do I need?
I'm pretty sure i'll need :
Head Unit (duh.)
Wiring harness (another duh.)
Mounting kit (yet another duh.)
Do I need an amp bypass or integration harness?
Thanks in advance.
Old Dec 1, 2009 | 04:04 PM
JCON's Avatar
JCON
I did my gf's 2000 V6 and let me tell you that amp behind the console/dash sucks but I removed the whole thing. Get a Ford explorer/Mercury Mountaineer kit. You'll have about 15' of extra wiring but that kit is a direct bypass. If you get stumped on it and you live near Delaware I can help you with it.
Old Dec 1, 2009 | 04:15 PM
SwishSkater
Can you give me a list of what i'll need?
Old Dec 1, 2009 | 10:58 PM
JCON's Avatar
JCON
You just need the Ford Explorer/Mountaineer kit that has the extra 15' of wiring. I tried using the one they gave me for the 2000 Mustang and it didn't work the way I wanted it to.
Old Dec 2, 2009 | 08:07 AM
SwishSkater
Do I have to get two of the kits..because there are two amps..right?
Old Dec 2, 2009 | 03:15 PM
JCON's Avatar
JCON
If you do what I did, you're by passing the amps and removing them completely.
Old Dec 2, 2009 | 04:20 PM
ttocs's Avatar
ttocs
as long as you don't have the mach system with the tweeters by the mirrors, you will have a super easy install. Get a for radio removal key and the deck and cd pop out in a few secs. The harness you will need is a standard ford, 70-1770 or fdo2b harness. You can also get a universal din pocket to cover the hole from the cd.
Old Dec 2, 2009 | 08:16 PM
SwishSkater
exactly what I was looking for. Is that all I'll need? I dont need any special bypasses or anything?
Old Dec 7, 2009 | 11:59 AM
ttocs's Avatar
ttocs
if it isn't a mach system you do not even need a kit as long as you get a single din sized radio. As I said a standard ford 70-1770 hrns and a universal din pocket to cover the cd player and it is a 30 min install for a newb....... It really does not get any easier so we would time ourselfs to see how fast we could do it. If you have the harness already wired and know what you are doing you can swap them in under 3 mins.....
Luke9222
Oct 22, 2015 11:55 PM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
cbird1177711
Sep 2, 2015 04:12 PM
