Head unit pre-outs ??
Old Feb 8, 2010 | 12:57 PM
DreamerGT's Avatar
DreamerGT
Default Head unit pre-outs ??
Im looking at some pioneer's and saw that some have 3 set of 4v pre-outs and others had 3 sets of 2v pre-outs. I was wonder if my Mach 1000 system would benefit from the 4v over the 2v? The receiver is the only thing I plan on changing nothing else.
Old Feb 9, 2010 | 11:33 PM
Iskwezm's Avatar
Iskwezm
if your using the speaker level outputs it doesn matter.If your using the RCA out puts, the higher the output, the more headroom youll have and not have to overdrive the amps.
Old Feb 10, 2010 | 11:57 AM
ttocs's Avatar
ttocs
if you are going to wire into the mach system and use the rca outputs you will need a line driver to get the voltage up around 8v where the stock amps are happy. With out it the subs will have weak output and leave the 2.5" speakers to play the bass which sounds bad.
Old Feb 10, 2010 | 12:56 PM
DreamerGT's Avatar
DreamerGT
So either way I need a line driver to feed the amps?
Old Feb 11, 2010 | 07:01 PM
ttocs's Avatar
ttocs
if you want the mach system to sound good yes. IF you are replacing speakers and bypassing the stock amps then no. There are a few different ways to go about it
Old Feb 12, 2010 | 09:15 AM
DreamerGT's Avatar
DreamerGT
interesting....
GimpyHSHS
19
Dec 19, 2023 01:12 PM
kevsgt
Oct 9, 2015 10:12 PM
lincolnshibuya
Oct 6, 2015 08:45 AM
jrrhd73must
Oct 2, 2015 09:17 PM
Drastang
Sep 30, 2015 03:48 AM
