W7 cuts out???
Old Mar 17, 2010 | 11:25 PM
bullitt1991's Avatar
bullitt1991
Default W7 cuts out???
Hi guys
I have a 12w7 a pdx 1.1000 watt amp a Rockford fostage 1f capacitor and a Pioneer Premier FH-P800BT head unit, when volume turned to a higher volume, the sub will cut out. Any ideas as to what it could be?
Old Mar 17, 2010 | 11:50 PM
TC3K101's Avatar
TC3K101
How is your gains set on the amp? what type of wire do you have ran? do you have any other electrical upgrades?
Old Mar 19, 2010 | 12:19 AM
bullitt1991
I have 1/0 guage power and ground wire
Old Mar 19, 2010 | 12:20 AM
bullitt1991
And the gain is only set about less then half
Old Mar 23, 2010 | 05:49 PM
msmith's Avatar
msmith
When an amp shuts off momentarily and then comes back on, it is almost always a voltage drop that exceeds the amp's protection circuit limits.
Check your ground connections (amp ground and the battery ground). They need to be tight and solid and to bare metal. Also check your fuse holder connections. Somewhere in your power wiring, there is something loose or not making good contact.
Old Mar 23, 2010 | 06:44 PM
JayMax03's Avatar
JayMax03
where did you ground it at?
Old Mar 25, 2010 | 10:16 AM
bullitt1991
I grounded where the rear passenger side seatbelt bolts to the car I sanded the crap out of it too
Old Mar 25, 2010 | 10:14 PM
joshs89gt's Avatar
joshs89gt
watch the lights on the amp - it should have a thermal overload light and thats probably what it is - fosgate amps are crap - anyway mine is - its a 600 db or something from a couple years ago probably 06 and its always done that with any decent subs or when it does handle it it'll cut out after too long, tried mounting it where it could get more air but that didnt help much.
jwog666
Dec 27, 2021 08:09 PM
piotrek53
Oct 13, 2015 06:54 PM
jrrhd73must
Oct 2, 2015 09:17 PM
mdg
Oct 1, 2015 07:04 AM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
