How to relocate a single fuse?
Fuse #9 spot is broken ( fuse for mach460 sound system )
I try to put a fuse and it doesnt hold it just falls out.
So how do i reloate that fuse so it's making a connection i know im proablly going to have to move the wire going into that spot but to another empty spot.
Will that work?
Any tips suggestion or write ups?
Will that work?
Is it broken or just not holding tight? If its just loose you may be able to squeeze it a bit tighter with some needle nose pliers (disconnect battery 1st lol). If it's broke, you may be able to re-route it to an empty acc spot in the fuse block but I'm not sure if the voltage is the same for the mach systems. I'd make sure with a voltmeter first. Sorry, I know nothing about the mach systems.
jwog666
Dec 27, 2021 08:09 PM
