DVD Headunit Install S-197 Models
Old Aug 16, 2012 | 03:21 AM
  #21
Kirbyeren's Avatar
Kirbyeren
Default Re
Nice and informative installing post buddy!! It will help me install DVD in my vehicle effectively... thanks for such a nice information sharing...
Old Dec 12, 2012 | 05:58 PM
  #22
mm7312's Avatar
mm7312
I have the Shaker 500 system and am installing the JVC kw-av60BT (I needed a physical volume control). But I was wondering, in the back of the head unit the RCA outputs are for front and rear, but the wiring harness only has one pair of RCA plugs. Do they connect to the front output on the head unit or the rear output?
Old Dec 12, 2012 | 09:35 PM
  #23
Xeno's Avatar
Xeno
'Dr. X'
I'm not 100% sure, but i'd imagine you'd need a secondary adapter to hook up the front and rear outputs
Old Apr 2, 2019 | 11:12 AM
  #24
Josh Townsend's Avatar
Josh Townsend
Default 09 mustang radio unit problem
I bought a pioneer head unit and adapting wiring harness to put in 09 mustang gt (shaker 1000) I tried to read up as much as possible before doing the task, but I'm running into issues. First, the harness that connects from factory to unit is not particular to this model mustang. The red/black wire on the stock harness that gives 12v on ignition is not in line with the adapting harness. I did move the wire to the correct pin. However, I still don't have 12v on ignition. As far as I know I've checked every possible fuse that may cause an issue there. I do have 12v constant going to my yellow on the aftermarket adapting harness though. Just not on the red to red/black. Has anyone else ran into this issue? From my understanding, you can hook up everything without the diode/resistor/ voltage regular it will just pop. I had a resistor soldered in line, but removed in trying to troubleshoot. From what I've read, this issue is only for 08/09 mustang's. I just haven't found enough info to try troubleshooting further. Can anyone help?
Old Apr 3, 2020 | 08:29 AM
  #25
bigcanoe's Avatar
bigcanoe
This was very helpful, even in 2020. Now, I have to hunt down a 1 amp diode since Radio Shack is gone. Thanks!
fastbackford351
Jan 29, 2016 06:30 PM
SatinSilverStang
May 31, 2012 04:40 PM
bigcanoe
Apr 21, 2009 11:30 PM
ReaperGT
Dec 15, 2008 10:23 PM
ajc
Sep 5, 2007 09:25 AM
