Speaker/sub wiring help
Old May 15, 2011 | 07:55 PM
OutlawFirebird's Avatar
OutlawFirebird
Default Speaker/sub wiring help
I just got my new amp for my 07 gt that had an shaker 500 system stock, I have put a new kenwood head unit in. My stock door subs dont appear to be working right with the new head unit, So i bought a new alpine amp. Im going to hook it up for now and in a week or so i will buy new door subs. But does someone have some information on runing new wires to my subs for the new amp, that i can use? I tried to do a forums search but did not come up with much, Its been a while since I have hooked a new amp up. And another quick question, my head unit has rear and front outputs on it, Is this for adding a amp for the front and rear spearks? thanks for your time and help, much appreciated.
Old May 15, 2011 | 11:48 PM
OutlawFirebird
well I got one door panel off today, will take other off tomarrow, ordering all my speakers and subs by tomarrow. should I worry about using those outputs for the speakers?
Old May 16, 2011 | 05:15 AM
ttocs's Avatar
ttocs
the amp/sub was working before you put the deck in right? Something is not connected right and adding an amp is probably alot more work then you need. I would not recomend using the stock speaker wires just because it would be difficult sort them out front to rear. Yes the RCA outputs are for and amplifier input.
Old May 16, 2011 | 01:14 PM
OutlawFirebird
im pretty sure they were working before, I have been wanting to put new speakers in anyways, so i order the shelby kicker set of subs and 4 speakers, So should I buy another amp for the 4 speaker to run through?, If so can you point me to a good one. would this work for my front and rear speakers. http://www.crutchfield.com/p_113KAC6...782&tab=review
Old May 16, 2011 | 10:05 PM
ttocs's Avatar
ttocs
never been a fan of kickers myself. I would recomend an amp for any kickers as with out power they are just never all there. Give them as much power as I can.
Old May 16, 2011 | 11:21 PM
OutlawFirebird
think that kenwood amp I have listed would power them enought?
Old May 18, 2011 | 01:34 PM
OutlawFirebird
I think I got the majority of it figured out. thanks
jwog666
Dec 27, 2021 08:09 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
lmurf60
Sep 24, 2015 10:07 PM
