Need some help installing this head unit.
Old Sep 26, 2005 | 04:16 PM
JohnnyCat281's Avatar
JohnnyCat281
Default Need some help installing this head unit.
Well, I need ALOT of help installing a unit into this Fox. It's a 91. I talked to the installer at the local car audio shop, and he wants 40 to install it. Since I'm a cheap, cheap bitch, and since it's a good thing to know how to do, I want to do it myself. Also, this head unit will only be in for a little while until I get another Alpine, I just found this head unit in my closet. I don't think the wires where messed with, because when Jose, the installer, looked at it, he took a 3 second glance and then said 40. He didn't seem to think the wires where re-routed, or ****ed with in general. There are 2 wire harnesses in the car, which threw me off, one harness has 6 wires attached to it, while the other one has 8. I took these pictures so that you could see better, I know they suck, my camera sucks pretty bad, but this can give you some idea.
Now, on the back of this head unit it says I need to connect the wires coming from the head unit to:
Memory B+
Black(gnd)
Red(B+)
Auto ant(blue)
Front Left SP(white, white/black)
Rear Left sp(Green, Green/black)
Front Right sp(Gray, Gray/Black)
Rear Right sp(Violet, Violet/black)
So reall what I need to know is what wires connect to other wires. I know it's hard to tell the colors on my pictures, so just circle them in MS paint or soemthing to show me which you mean. The only wire I know is red, which is hot, which I found out...
I know it's confusing and hard to tell by the pictures, but even if you only know one of the connections, lemme know, anything helps.
THanks alot.
Any questions, I'm always on aim and I'll answer your question asap. TooAgg4you
cbird1177711
Sep 3, 2015 08:43 PM
amandahchase
Sep 3, 2015 10:09 AM
cbird1177711
Sep 2, 2015 04:12 PM
kawiguy827
Sep 1, 2015 07:09 PM
