2013 premium convertible shaker upgrade
Old Mar 14, 2014 | 06:05 PM
hubdawg's Avatar
hubdawg
Default 2013 premium convertible shaker upgrade
New rig and would like to keep the stock HU, sync and prefer not put a sub in the trunk. There are a lot of posts but most don't deal with verts and would like to keep the system looking stock so it doesn't exit the car when the top is down. I'd like to keep a budget of 1k and be able to add on as desired. I was thinking of adding an amp and changing the subs in the door to higher quality. Do the door subs have their own amps and if so are they sufficient.
Old Mar 14, 2014 | 06:27 PM
jz78817's Avatar
jz78817
Of course they have their own amps. Each door sub is powered by its own 110 watt amp. You're not going to be able to do much better with any 8" you can fit in there.
Old Mar 15, 2014 | 11:43 AM
hubdawg's Avatar
hubdawg
Yeah I'm thinking should be fairly easy to beat a paper factory speaker but wondered if the amps should be replaced with a better cleaner unit..of course
mungodrums
Oct 7, 2015 04:01 AM
algregory
Sep 11, 2015 11:44 AM
Roush05
Sep 10, 2015 12:23 PM
spamedic
Sep 9, 2015 12:15 AM
vintageaion
Sep 8, 2015 10:45 AM
