Quick Question
Old Oct 20, 2005 | 08:27 PM
v6stang1335's Avatar
v6stang1335
Default Quick Question
If you bridge a two channel amp it presents a 4ohm load right? well can I u wire up my 4ohm DVC sub to present a 2ohm load on the bridged amp even though the amp is at 4ohm? or Will that blow my amp?
Old Oct 20, 2005 | 11:56 PM
pj1010's Avatar
pj1010
Default RE: Quick Question
Amplifiers do not "present" any resistance in this light.
If each coil of your subs is 4 ohms, hook them up in parallel and you will have a 2 ohm sub.
What sort of amplifier do you have?
Old Oct 21, 2005 | 01:01 AM
v6stang1335
Alright thanx for correcting me but wat i'm asking is that people are talking about amps when bridged are only stable at 4ohms and not 2. Is this true if my amp is bridged will it blow if i have my sub wired to 2ohms?
Old Oct 21, 2005 | 09:36 AM
pj1010's Avatar
pj1010
Again...what amplifier do you have?
In a nutshell, "stable at 4 ohms bridged" means the amplifier can safely handle 2 ohms per channel. Running anything less is putting you into a "grey area" of outcomes. Your amp could fry, it simply might not even turn on, it might overheat, or hell it might even work fine (doubtful). Who knows....this is dependent upon the amplifier.
HOWEVER, general consensus will be that if the mfgr. says the amplifier is only stable at 2 ohms per channel, do not go below that.
Old Oct 21, 2005 | 05:04 PM
v6stang1335
It's a Pyle Dryver Plad413 (It's 4 channel) and 2ohm stable i'm just not sure if that applies in bridged mode or not. I'm new to this and i want to learn more about it. (I got the amp from my cous for free brand new) so i'm not sure how good it is.
Old Oct 21, 2005 | 07:29 PM
pj1010's Avatar
pj1010
Pyle...I'm guessing 2 ohms per channel.
tmdm
May 2, 2021 02:49 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
svfetter
Oct 5, 2015 11:39 AM
treesloth
Sep 28, 2015 07:03 AM
Big Al's 03
Sep 15, 2015 09:05 AM
