Shaker 1000 Door sub replacement -2005
Old May 18, 2020 | 09:44 AM
3stang's Avatar
3stang
Default Shaker 1000 Door sub replacement -2005
​​​​​​Folks, I have a blown passenger subwoofer on a 2005 mustang with shaker 1000. I was told that I could just replace it with an 8" sub and would not have to take the door off to replace. I've taken the trim ring off and the speakers bolts but it isn't coming out. Was I lied to and the door has to be removed for this replacement? Also, I understand I can't just use any 8" subwoofer. I was told the CompC kicker 8" subwoofer would be a direct replace, but would prefer to find out for sure first, or if I should just try and find the same Ford replacement as this shaker has a unique setup and requires a special ohm range, etc....
Any help from someone who knows this system would be appreciated.....thanks!
Old May 18, 2020 | 01:35 PM
Derf00's Avatar
Derf00
Gentleman's Relish
A simple search on the site would provide you with all the information you need to know and answers to your question.
https://mustangforums.com/forum/audi...through-2.html
https://mustangforums.com/forum/v6-s...and-specs.html
Old May 19, 2020 | 10:41 AM
3stang's Avatar
3stang
sorry, I'm new and still getting used to site and I went to the root of this topic and forums but didn't see a simple search button. Thanks for providing links
Old May 21, 2020 | 05:05 PM
Derf00's Avatar
Derf00
Gentleman's Relish
No problem, by the way, one thing that is kind of not clear. When first removing the stock sub, you MUST remove the door panel to get the stock subwoofer out. The subwoofer has a bolt that goes through the rear of the speaker magnet to the enclosure it sits in to prevent rattling. Once you have that bolt out, if you decide to plug the hold and not use it, you will be able to install/remove the sub without taking the door panel off.
deltafool117
Feb 20, 2018 08:43 AM
smoon86
Oct 20, 2010 11:06 AM
maxshuty
Feb 18, 2009 06:38 PM
funtimesalways
May 11, 2008 09:39 PM
drtuba
Aug 29, 2006 02:57 PM
