Wiring Problems
Old Jan 16, 2006 | 01:04 PM
Sinister Audio's Avatar
Sinister Audio
Default RE: Wiring Problems
they all are but the dash are 3.5"s and they absolutely suck and cant handel any power anyways.
Old Jan 16, 2006 | 01:05 PM
pj1010's Avatar
pj1010
Right on...screw em then.
Old Jan 16, 2006 | 06:46 PM
90VERTGT's Avatar
90VERTGT
SDelgado,
I just dealt with this dilemma in my 90 vert. I went through the same BS
that your going through until I found a hint online somewhere. There are a factory
set of rectangular plugs with individual grounds hidden behind the radio/ac area. It
took me a while to finally get out the flashlight and crawl around on the floorboard but
I did and HOLY CHIT!!!!! They are hidden in there. They look exactly like the ones you
unhooked from the ford factory radio. Rectangular, not the square ones coming in and
out of the amp! You pop the little plastic clip holding them to the passenger side of the
a/c frame thingy and pull them down. Simply unhook the harness(which runs to the
square amp plugs) and plug your aftermarket harness right in there. No special amp
bypass this or that. You just plug it in like it's supposed to be. If you look the black
speaker plg has all 8 wires including individual grounds . I just tried mine this past
weekend and finally got tunes! Don't hold me to it if your car year/model is different
But worth a look!
Good Luck 90VERTGT
Old Jan 18, 2006 | 05:53 PM
90VERTGT's Avatar
90VERTGT
Any luck ?
Old Jan 31, 2006 | 01:52 PM
stangcrazy's Avatar
stangcrazy
Just buy a set of bass blockers. They will work fine.
2007StangV6
Jan 28, 2016 06:09 PM
Doogie65
Sep 6, 2015 02:55 PM
zanemoseley
Sep 6, 2015 12:58 PM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
