help with new headunit
Old Jan 26, 2006 | 12:50 AM
tony28's Avatar
tony28
Default help with new headunit
ok i just finished wiring up a new headunit with a harness in my 99 GT and i put everything back in but when i try to turn it on it has no power. ive double checked all the connections and plugs. everything is wired correctly. so i took it back out and put the stock radio/cd player back in. it has no power either. so why is there no power? a blown fuse maybe?
Old Jan 26, 2006 | 02:42 AM
MadDog717's Avatar
MadDog717
Default RE: help with new headunit
It is most likely a fuse.
Old Feb 12, 2006 | 05:42 PM
BlackSVTsnake302's Avatar
BlackSVTsnake302
I have the same problem right now, I checked all my fuses???[:@]
Old Feb 13, 2006 | 06:47 PM
1fastzook's Avatar
1fastzook
it's probally a fuse check the fuse under the dash i dont know what year your car is but if it has a fuse box under the hood check there too.see if an thing else dont work like the dome light,cig lighter and check those fuses also you may have to run new wires
sanitarium16
Mar 8, 2006 10:16 PM
clapton_rocks
Oct 12, 2005 12:07 AM
Epon
Oct 3, 2005 01:52 AM
JayCe
Aug 10, 2005 06:15 PM
timbo3282
Jun 15, 2005 11:09 PM
