The Diamondback
Hmmm...it looks like the forum code is registering that it's an image, but not displaying it.
Go into your photobucket account, and verify that you can see the image there. Click on the thumbnail of it to pull up a larger image, and if it's still there, then look on the right hand side. You'll want to copy and paste the "Image Code" into the text box here on the forum. It should have [IMG] around the link.
That should work...
That should work...
You don't have to pull up the larger image, but I find that it helps because then I know exactly what photos I'm putting up, in case I took multiple of the same scene. You can also hover over the thumbnail and the links will pop up, as long as you get the [IMG] one it should work, but it looks like you got it so no worries.
