push button start
push button start
Due to ignition switch problem, I would like to take this opportunity to a desired mod to a vehicle. I would like to remove the ignition switch(which I have done tonight) and add a on/off toggle switch in its place and a push button start to replace the cig lighter(which was also removed tonight).
Here is my question, there are four wires yellow, red, black and red plus other color. Please help me identify the following color and also which wire do I connect to the on/off toggle and which wire do I connect to the push button.
Any help would be greatly appreciated.
Thank you for all the help.
Shouldn't be all that hard to do. One 12v in, one goes out to starter, one goes out to fuse box and the other goes out to accessories. Red is the accessory, yellow is 12v in from the battery. Not sure the colors of the others and be sure to check these with a meter before hooking it up.
Once you have them sorted then you have 12v in to the toggle. On the other side of the toggle goes to the fuse box, accessories and then a line to the push button. The other side of the button goes to the starter.
