Broken Bolt!
Old Mar 17, 2006 | 07:52 PM
68Midnight's Avatar
68Midnight
Default Broken Bolt!
The bolt that goes to the powersteering into the block broke and half of it is still in the block. How do I remove it? Theres nothing sticking out btw, its all in the hole.
Old Mar 17, 2006 | 07:53 PM
Twister's Avatar
Twister
Default RE: Broken Bolt!
try an easy out first, then try cutting a slot in it and use a screw driver
Old Mar 17, 2006 | 07:54 PM
68Midnight's Avatar
68Midnight
Easy out? Can I get a translation on that? Im not too familiar with the term..at all. And how would i cut a slot and use a screw driver?
Thanks!
Old Mar 17, 2006 | 08:00 PM
Soaring's Avatar
Soaring
I ♥ Acer
An easy out is sort of a drill bit. First, you have to make a hole in the center of the bolt with a real drill bit, then you insert the easy out. The threads as such on the easy out are reversed to the drill bit, so will grab the inside of the bolt and spin it out. If that doesn't work, then you have to completely drill out the broken bolt and re-thread the hole with a slightly larger thread maker. Tool and die ......
Old Mar 17, 2006 | 08:05 PM
68Midnight's Avatar
68Midnight
coo. thanks
Old Mar 18, 2006 | 01:28 AM
fireball580's Avatar
fireball580
my dad taught me the trick of welding a big nut to the broken bolt.
it is a great trick if you have a welder,after you get the nut welded to the bolt spray it down with some penetrating oil and bam out comes the bolt when you start wrenching on it sometimes i found that it takes a couple of tryes to get it out but it works verry good.
i like to do that because i have never been good at drilling out bolts
GimpyHSHS
19
Dec 19, 2023 01:12 PM
baddog671
Jul 26, 2016 01:20 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
2poor4u2
Sep 26, 2015 11:08 AM
Sep 25, 2015 06:58 PM
