Will not turn over?
Old Apr 16, 2006 | 12:52 AM
ttiaga's Avatar
ttiaga
Default Will not turn over?
Ok, I am at a loss here.
I was ready to turn over my new 302 (it's in a 68 mustang coupe), and when I attempted to, the solenoid clicked, the started engaged, but the engine would not turn over.
The engine is new, the trans is a new rebuilt c4 (jackson racing), new starter, new battery, new solenoid, I am at a loss.
Any suggestions on what I should look for??
Thank you,
Ted
Old Apr 16, 2006 | 12:58 AM
ideal_mustangs's Avatar
ideal_mustangs
Default RE: Will not turn over?
First check all the connections. Make sure they're all tight and clean. If you say that you starter is engaging but won't turn the motor over, make sure you can turn the motor over by hand. I would say bad connection somewhere though
Old Apr 16, 2006 | 01:07 AM
6mustang6's Avatar
6mustang6
sounds like a locked up engine to me. or possibly a dead or weak battery or loose connection. Hopefully, it's not the first thing.
Old Apr 16, 2006 | 01:16 AM
tylerdru's Avatar
tylerdru
I assume he is talking about a brand new engine.
Old Apr 16, 2006 | 01:21 AM
6mustang6's Avatar
6mustang6
yeah, Try and turn the engine by hand first.
Old Apr 16, 2006 | 01:29 AM
slickman's Avatar
slickman
Just because the starter is new, does not mean its not bad. Don't think the worst, check all the connections and if everything is good make sure you have 12 volts going to the starter. Then pull the starter out and bench check it to make sure its working right. You can also turn the engine over by hand to make sure its not locked up.
ORIGINAL: ttiaga
Thank you,
Ted
Old Apr 16, 2006 | 01:56 AM
ttiaga's Avatar
ttiaga
Well, it looks like it is engine related. I have tried to turn it over by hand, no luck.
Any ideas on what to check on the engine as to why it may be locked up?
The engine is a "new" engine from recon.
Ted
Old Apr 16, 2006 | 02:06 AM
6mustang6's Avatar
6mustang6
well it would be tough to turn a new or rebuilt engine by hand. maybe try loosning sparkplugs to relieve compression and turn it. Idk.
Old Apr 16, 2006 | 02:27 AM
ttiaga's Avatar
ttiaga
Just loosned sparkplugs and still cannot turn it over.
Old Apr 16, 2006 | 02:28 AM
slickman's Avatar
slickman
This is also a good idea.. I broke in engine is hard to turn over let alone a new one..
ORIGINAL: 6mustang6
