Will not turn over?
Old Apr 18, 2006 | 08:34 AM
  #31
slickman's Avatar
slickman
Default RE: Will not turn over?
When you first put the TC on the input shaft of the transmission, you will be able to turn it. Then you will feel it pop into a grove and go onto the shaft about an inch or so more. Then its seated and you still should be able to turn it.
ORIGINAL: ttiaga
How can I check to see that the tq is seated correctly?
Old Apr 18, 2006 | 07:48 PM
  #32
ttiaga's Avatar
ttiaga
Everything is looking good. I put the tq on the trans shaft, no problems. It turns without issue. I am going to bolting the engine up here shortly and will give it another shot at turn it.
More to come..
Old Apr 18, 2006 | 09:46 PM
  #33
ttiaga's Avatar
ttiaga
Thank you everyone. The engine has official turned over and is looking good. Going to finish the prep on it, then hopefully this evening I will be starting it.
Ted
Old Apr 22, 2006 | 02:42 AM
  #34
ttiaga's Avatar
ttiaga
Final update from me on this topic. The engine started and is looking good. The only problem now is it looks like I may have damaged the main trans seal when I installed the torque converter wrong the first time.
Live and learn.
Ted
Old Apr 22, 2006 | 10:03 AM
  #35
slickman's Avatar
slickman
Great new about geting it running..
[sm=ttiwwp.gif]
ORIGINAL: ttiaga
Live and learn.
Ted
Old Apr 22, 2006 | 10:09 AM
  #36
TNT1968's Avatar
TNT1968
Ditto great news! [sm=smiley20.gif]
4cylinderplus2
Oct 9, 2020 07:45 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
breaking
Oct 2, 2015 01:27 PM
Sep 30, 2015 12:39 PM
logan409
Sep 26, 2015 07:43 PM
