how to put a distributor back
Old Apr 19, 2006 | 12:31 AM
jts302's Avatar
jts302
Default how to put a distributor back
well i took the distributor out and me being an idiot forgot to mark it i read that you take the #1 spark plug out and stick your finger in the hole intill you feel pressure and then you put it to 0 or TDC and then you mark on the distributor were #1 should be point the rotor an inch left of the mark and then you put the distributor back and it should fall close to the mark . is this info correct or is there a easyer or better way of doing it THANKS
Old Apr 19, 2006 | 12:35 AM
ideal_mustangs's Avatar
ideal_mustangs
Default RE: how to put a distributor back
That will get you in the ballpark. Start it up then and re-time it.
Old Apr 19, 2006 | 12:44 AM
jts302's Avatar
jts302
I have another question theres two places on my distributor two put a vacuum line were do i connect the lines to i know one goes to the carbbut not sure were the other goes
Old Apr 19, 2006 | 12:54 AM
ideal_mustangs
your other one is for retard. It's basically an emmissions control thing. It's supposed to go through a switch, but basically goes to the manifold.
drfister
May 3, 2018 10:38 PM
mirandaandjimmy
Nov 16, 2015 08:51 AM
1987gt40ttopt
Aug 28, 2015 10:49 PM
jesse1125
AmericanMuscle.com
Aug 26, 2015 02:34 PM
Philhampton1
Aug 21, 2015 12:04 PM
