Tighten up steering?
Old Apr 20, 2006 | 12:30 PM
slickman's Avatar
slickman
Default RE: Tighten up steering?
That is some great info!! It answered one of my questions right off and the rebuild price is also a great deal!!!
ORIGINAL: ttoney
http://www.stangerssite.com/adjustment.html Here is a bunch of good info on adjusting your steering box.
This guy also does rebuilds, resonably priced, and the difference is amazing.
http://www.stangerssite.com/steering_box.html
Old Apr 20, 2006 | 08:56 PM
slickman's Avatar
slickman
Well, I went and did some minor adjustments to get some of the play out. I just adjusted the screw in after loosing up the lock nut and it took about 50% of the play out. Its the screw and lock nut that's on top of the gear box.
Old Apr 20, 2006 | 09:30 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yep...worked, didn't it?
Old Apr 20, 2006 | 09:38 PM
slickman's Avatar
slickman
Yup, seem too. I can't adjust it anymore than it is. I did not force it but, there did not seem to be any more adjustment left. If it last me a year or two, I'm happy with that. My slush money is all gone anyway..
ORIGINAL: Soaring
Old Apr 20, 2006 | 09:46 PM
Soaring's Avatar
Soaring
I ♥ Acer
It'll last you for many years as long as you don't drive it for 50K miles a year. Those old boxes are tougher than nails.
Old Apr 20, 2006 | 09:54 PM
slickman's Avatar
slickman
That would be great.. I just got a set of new rear spring I'm going to be installing.. They will raise the rear 1 1/2 inches over stock then I can take off them POS air shocks. I have a new set of KYB's to install too..
ORIGINAL: Soaring
Old Apr 20, 2006 | 10:26 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: slickman
Thanks Soaring
Did you do this adjustment? It states to take the pitman arm off. I'm not sure it that's needed or not but, from the adjustment steps pic I posted it appears that the shaft that the pitman arm mounts too is the shaft that gets turned in order to tighten up the slop? Is that correct?
ORIGINAL: Soaring
ORIGINAL: 6mustang6
yeah, on the steering box, there is a nut, loosen it, and then tighten the little screw.
The right way to do it, is to turn your steering wheel to the left as much as it will go, then loosen the nut on the steering box, and use a screw driver to tighten it until it rubs, then back off a tad, then tighten down the nut. If you tighten it with the wheel straight, you will get it rubbing too much and will cause undue premature wear.
Have I done that adjustment? Yes.
lincolnshibuya
Dec 8, 2020 01:49 PM
CS2007
Jun 25, 2019 09:45 PM
Sixer4Life
Oct 12, 2015 04:26 AM
allenmaty
Sep 24, 2015 09:17 AM
stark777
Sep 21, 2015 12:46 PM
