pcv hose
Old Apr 24, 2006 | 10:16 PM
jman67's Avatar
jman67
Default pcv hose
I just replaced the stock carb and manifold on my 289 with an edlebrock carb and manifold. Now I don't know where to connect the pcv tube that originally came frome the passanger side valve cover to the base of the carb. There is a port at the base of the new carb but the instructions said that it is for power brakes so I just put a plug in that port. Your help is appreciated
Old Apr 24, 2006 | 10:28 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: pcv hose
The PCV valve hose goes to the spacer at the bottom of the carb. If you don't have a spacer, get one. The port at the base of your new carb is most likely a vacuum port.
Old Apr 24, 2006 | 10:33 PM
slickman's Avatar
slickman
There should be a port on the bottom flange in the back. I just put a new Edelbrock 500 on mine and that were mine was I think.
ORIGINAL: jman67
Old Apr 24, 2006 | 10:36 PM
Soaring's Avatar
Soaring
I ♥ Acer
Dang Slick, I thought I taught you better grammar than that.
Old Apr 24, 2006 | 11:35 PM
slickman's Avatar
slickman
Sorry dad... [sm=bangbang.gif]
ORIGINAL: Soaring
lmurf60
Sep 24, 2015 10:07 PM
Ipaman
Sep 22, 2015 07:01 AM
Demodulates
Sep 18, 2015 11:14 AM
TfcCDR
Sep 14, 2015 12:08 PM
MusicCity615
Sep 12, 2015 07:05 AM
