Removing Master Cylinder
Old May 8, 2006 | 11:42 PM
ideal_mustangs's Avatar
ideal_mustangs
Default Removing Master Cylinder
Im in the process of changing the MC on my 68. I am putting one out of the granda for the disc swap and was under the impression that the rod stayed on the car and was used with the granada. It isn't coming out though. Is it suppoes to?
Old May 9, 2006 | 11:23 AM
ideal_mustangs
Default RE: Removing Master Cylinder
Does no one know if the rod is supposed to stay in the car or not??
Old May 9, 2006 | 01:14 PM
highhilleer's Avatar
highhilleer
IIRC you remove the rod from the pedal, remove brake lines and unbolt. Remove mc and rod as a unit. Put the rod in a vise and tug out the rod - it will not be easy.
http://www.mustangsteve.com/mc_rod_remove_close.jpg
This is from the MustangSteve site for the disc swap
http://www.mustangsteve.com/granadadiscs
(He recommends a 74 Maveric mc. I believe the reason is the brake lines are on the driver's side, same as original mc. Are the lines on the Granada mc on the other side?
Old May 9, 2006 | 02:12 PM
ideal_mustangs
The ones for the granda were on the same side as the mustang, so thats what I got
GimpyHSHS
19
Dec 19, 2023 01:12 PM
jwog666
Dec 27, 2021 08:09 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
Dathan
Oct 5, 2015 05:52 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
