turn signal problems
Old May 10, 2006 | 01:43 AM
catfish's Avatar
catfish
Default turn signal problems
i have a 289 66 mustang coupe and i was experiencing problems with my brake lights and turn signals. so i replaced sockets, turn signal switch and stop lamp switch. now my brake lights work good but my turn signals rarely work. every now and then theyll work. could it be a grounding issue? any help would be greatly appreciated.
Old May 10, 2006 | 01:53 AM
SuperHoss's Avatar
SuperHoss
Default RE: turn signal problems
If your front lights are not blinking either the problem may be with your blinker cam in steering column.
SuperHoss's Avatar
SuperHoss
I had the same problem.
Old May 10, 2006 | 01:55 AM
catfish's Avatar
catfish
i did that and they worked for a couple days and now they dont should i replace it again?
Old May 10, 2006 | 04:04 AM
SuperHoss's Avatar
SuperHoss
The metal prongs (looks kind of like a thick silver wire) on the back of the cam are the important part, carefully bend them down where they will be sure to touch the brass prongs in the column(there should only be two on the column, be sure not to go too far), and make sure the cam is properly locked down. This was the cause of my problem.
Old May 10, 2006 | 03:17 PM
SuperHoss's Avatar
SuperHoss
I may be wrong, there may be 4 brass prongs in the steering column. (Its been a while since I've done mine)
Old May 10, 2006 | 05:27 PM
catfish's Avatar
catfish
the 2 wires are making good contact with the brass buttons. i drove it around the block and out of 4 or 5 turns it works once or twice. i dont know if somethings shorting out. i might have to break down and take it to somebody that knows more than i do.
Old May 11, 2006 | 02:00 AM
SuperHoss's Avatar
SuperHoss
Your idea is better...get someone that knows what is going on, I got lucky and found my problem but not everyone has the problem I had. I have the Scott Drake sequential tail-lights and cooked my new flasher relay when I sodered the cam wires. Strangely enough, the surge also fried my brake light switch...after replacing the two switches everything worked fine.
Old May 11, 2006 | 02:27 AM
catfish's Avatar
catfish
theres an all mustang shop by my house so im gonna take it there. thanx for tryin to help me.
musnicki
Sep 23, 2015 07:11 AM
5.0 kevo
Sep 3, 2015 06:24 PM
cbird1177711
Sep 2, 2015 08:51 PM
iculookin
Sep 2, 2015 12:34 PM
