Cleveland heads??
Old May 15, 2006 | 03:52 PM
daver's Avatar
daver
Default Cleveland heads??
Just wondering, do you have to run an aftermarket piston to use the cleveland heads on a windsor block?? Or can you notch them with a die grinder er somethin?? Im lookin at a clevor setup.
Old May 15, 2006 | 04:17 PM
Decurion's Avatar
Decurion
Default RE: Cleveland heads??
https://mustangforums.com/m_1372635/tm.htm
see above thread for arguments. stick with the windsor stuff. and wouldnt that be a windsland? since you start with a WINDsor block and top it with cleveLAND heads? you can pick up a set of aluminum windsor heads in the $1000 range, much less if you want to go used. and they will be far lighter and flow far better than the cleveland heads, assuming both are box-stock.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mustangheaven
Jan 3, 2016 11:20 AM
kevsgt
Oct 9, 2015 10:12 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Drastang
Sep 30, 2015 03:48 AM
