Rebuilt Engine Back In
Old May 22, 2006 | 02:53 PM
  #21
Smothers's Avatar
Smothers
Default RE: Rebuilt Engine Back In
ORIGINAL: slickman
Looking good man!!! Gota love them 289's....
Thanks Slick! I do love that its a 289. Although with the 302 crank and rods, I guess technically it could be considered a 302. Maybe not. Looks like my engine may have an identity crisis
Old May 22, 2006 | 02:59 PM
  #22
slickman's Avatar
slickman
Well, its technically a 302 with that crank in there. The problem is the cylinder walls on a 289 block are shorter than a 302 block. That's why Scott told you to limit the RPM's.. It puts allot of stress on the lower section of the cylinder wall at high RPMs.. Just don't beat on it and it should be fine.
Typically you can use a 289 crank in a 302 block but normally not the other way around. You sure that's a 289 block?
ORIGINAL: Smothers
ORIGINAL: slickman
Old May 22, 2006 | 03:16 PM
  #23
PONYBOY65's Avatar
PONYBOY65
LOOKS GOOD!
Old May 22, 2006 | 03:44 PM
  #24
Smothers's Avatar
Smothers
ORIGINAL: slickman
ORIGINAL: Smothers
ORIGINAL: slickman
Yep i'm sure. Check out this old post:
https://mustangforums.com/m_982566/tm.htm
Old May 22, 2006 | 03:46 PM
  #25
Smothers's Avatar
Smothers
ORIGINAL: PONYBOY65
LOOKS GOOD!
Thanks PB65!
ShaneB26154
35
Mar 4, 2021 04:05 AM
msavoia23
12
Jul 7, 2018 12:08 PM
Urambo Tauro
Sep 7, 2015 12:47 PM
01blackgtconv
Aug 10, 2015 01:25 PM
vbonina
Aug 6, 2015 02:56 PM
