Scratches on Piston Skirts
Old May 24, 2006 | 09:38 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Scratches on Piston Skirts
ORIGINAL: 06stangtime
It's piston wabble(normal) on older engines and is no big deal, Just make sure sure the scratchs are not to deep, If it makes you feel better
just replace them...
Sounds like a complete overhaul with either replacing the block or sleeving the one you have. Get it right the first time.
Old May 27, 2006 | 06:21 AM
66stangstable's Avatar
66stangstable
The machine shop should let you know how your cylinders look as far as warping and damage goes, but if your cylinders are wore out then you can't go over .040" bore because your cylinder walls will be too thin and overheating will occur (unless you sleeve them) But if your block is ok I would definitely replace the pistons and have the rods checked, the clearances are so minut it takes little to nothing to screw up an eng. my feelings have always been its better to be safe than sorry, if money permits anyway lol. Good luck and keep us posted.
Old May 27, 2006 | 08:27 PM
acidrain088's Avatar
acidrain088
In theory pistons are not supposed to touch the side of the cylinder but in real life they do. That's why they make teflon coated pistons. It happens but if there is too much heat the pistons skirts will get all scuffed up.
Old May 28, 2006 | 02:34 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
do the scratches catch ur finger nails? if so and not to deep and the bores are within tolerance take some 800-1000 grit wet sand paper and knock down the scratches!
poke68
Dec 16, 2025 03:36 PM
uberstang1
Dec 7, 2017 07:10 AM
degner122
Sep 16, 2015 07:09 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
mustangchef
Sep 4, 2015 08:08 PM
