timing chain cover question
Old May 27, 2006 | 03:58 AM
PONYBOY65's Avatar
PONYBOY65
Default timing chain cover question
hi guys im going to put on my timing chain cover tomorrow, but was wondering what kind of gasket maker to use...i already baught the timing chain cover gasket kit, but dont know which gasket maker to use or procedures to follow? i have the blue gasket maker, super blue gasket maker, and gasket sealer. I think im good to go...any suggestion on installing my timing chain cover?
Old May 27, 2006 | 11:15 AM
69mach1377's Avatar
69mach1377
Default RE: timing chain cover question
I have used the orange silicon, spread very thin on both sides with good success. Clean both metal surfaces with brake cleaner and rag before application.
Old May 27, 2006 | 07:21 PM
THUMPIN455's Avatar
THUMPIN455
with a gasket you shouldnt have to use sealer on all of it. The edges where it meets the oil pan and around the water outlets are the only places I put it. I prefer Ultra Black, use it sparingly, not a huge glop of it. Whatever squishes out does so on both sides. A quick way to spin a bearing is to have some get into the pan then go through the oil system.
Orange works okay too, so does blue. Black seems to hold the longest and clean up easiest. All you need is a thin layer of it spread around the cover then the gasket applied over it. I dont reccomend putting it on the block, its easier to clean the cover then the block with the engine in the car.
Old May 27, 2006 | 10:27 PM
Color by WEASEL's Avatar
Color by WEASEL
I used the orange on mine with no worries. But, like the postbefore, use it sparingly. I dab and smear to get a smooth even, thin coat. Good luck.
Old May 28, 2006 | 02:38 AM
PONYBOY65's Avatar
PONYBOY65
i used ultra blue and im almost done...i had to work today so i couldnt finish[:@]...yes i didnt over do it on with the gasket maker...i left it nice and smooth and put everything together nicely...thanks for the help! hope fully tomorrow i'll finish and start driving! thanks again
waid302
Sep 14, 2015 11:19 AM
GimpyHSHS
Aug 29, 2015 06:30 PM
1st 4 eyed fox
Aug 24, 2015 06:56 PM
ding56
Aug 14, 2015 02:40 AM
