Wheel spacers/adapters?
Old Jun 15, 2006 | 07:39 PM
6mustang6's Avatar
6mustang6
Default RE: Wheel spacers/adapters?
what center caps are those???? My 03 GT rims have mustang emblems.... ACtually they are made alittle different...........
Old Jun 15, 2006 | 07:45 PM
67t5ponycoupe's Avatar
67t5ponycoupe
They have the Ford blue oval in the center
Old Jun 15, 2006 | 09:47 PM
Soaring's Avatar
Soaring
I ♥ Acer
If you go more than 3/16 " with a spacer, you are at risk of breaking off the lug bolts. Why in helll do you younguns want to push the mods so far that you endanger yourselves and others in the car just because you want a restomod look with wheels that were not designed to be used on your classic Mustang?
Old Jun 15, 2006 | 10:33 PM
BeastMachine69's Avatar
BeastMachine69
Soaring I see your point but, 15's are just not as hot as 17's or 18's. And unfortunately these late model wheels don't fit our early mustangs.
Old Jun 15, 2006 | 10:34 PM
67t5ponycoupe
That is only with the spacers that slide onto the lugs and then you put your wheels on. The type I'm running bolt to the rotor just like a wheel and then the wheel bolts to that on a separate set of studs. Done correctly it works fine.
Old Jun 15, 2006 | 11:37 PM
6mustang6's Avatar
6mustang6
yes, I am buying the ones that bolt on first. Like 67ponycoupe.
jwog666
Dec 27, 2021 08:09 PM
UrS4
Oct 3, 2015 06:23 AM
mungodrums
Sep 28, 2015 10:54 PM
folivier
Sep 26, 2015 02:28 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
