Grant Steering Wheel installation tips
Old Jun 17, 2006 | 01:44 AM
texasbluesdownunder's Avatar
texasbluesdownunder
Default Grant Steering Wheel installation tips
G'day all,
I have just finished installing a Grant Classic Nostalgia steering wheel to my 66 coupe.
Thought I might post a tip that may save time for others.There is a spring for use under the horn button that needs to be discarded and 3 foam adhesive pads are to be stuck over the 3 rivets on the contact plate.
Also the fibre contact plate in my installation kit was TOO BIG for the horn button to locate on to.I had to rework the round fibre contact plate with emery paper until it was an interference fit.Now it fits on.
I wouldn't recommend these wheels.I think the quality is so so.I guess the old saying "you gets what you pays for" holds firm.
I'll run with this wheel until I can get my deluxe wheel repaired.It has the typical splits in the plastic.I read there is a guy in Pennsylvania that restores them for around $400 US but I'll try and find some one in Australia or have a go at it myself.
Regards Ron Downunder
Old Jun 29, 2006 | 12:38 AM
crunchyskippy's Avatar
crunchyskippy
Default RE: Grant Steering Wheel installation tips
I got that steering wheel for my 67 and had the same issues! The center cap fell off quite a few times before I *twisted* the cap to stay on the fiberboard. I eventually became too lazy to disconnect the battery everytime I reinstalled it. Neighbors must have thought I was crazy honking so much.
Now if I could just figure out how to get the 1/4" gap from behind the wheel to the column...
Old Jun 29, 2006 | 12:56 AM
6mustang6's Avatar
6mustang6
Same here. My button keeps falling off. It must have ground off the fiberboard. Im getting ready to glue it. but my horn works fine. I kept the spring and everything.Oh, the foam pieces dont go on the rivets.... The rivets are what contact to make the horn work.
Old Jun 29, 2006 | 12:57 AM
Cogtx's Avatar
Cogtx
ORIGINAL: texasbluesdownunder
G'day all,
Ron...same thing here. Installed the Grant with similar mods you mentioned. My copper horn contacts on the signal assembly were worn so far down that the Grant contact plate was making contact with the emergency flasher and turn signal contacts causing a short. Ended up placing the metal caps from glass fuses over the contacts (perfect fit) and all was well (see pic below). My son really likes the feel and size of the 15" Grant wood wheel...guess it'll do for now...
[IMG]local://upfiles/19071/AA34EB9A75D84D52B1C8AE00F99C07F5.jpg[/IMG]
Old Jun 29, 2006 | 01:06 AM
6mustang6's Avatar
6mustang6
Hey Cogtx, What is that lever sticking out of the right side of the column? Is that a column shift car?
Old Jun 29, 2006 | 01:18 AM
Cogtx's Avatar
Cogtx
ORIGINAL: 6mustang6
Not quiet....broken emergency flasher **** screw...had to unscrew and replace with another...
Old Jun 29, 2006 | 01:21 AM
6mustang6's Avatar
6mustang6
oh, i know my dads 67 is lower down the column then that one, but he has tilt wheel.
Old Jun 29, 2006 | 09:20 AM
jes72mustang's Avatar
jes72mustang
"Ended up placing the metal caps from glass fuses over the contacts (perfect fit) and all was well (see pic below). My son really likes the feel and size of the 15" Grant wood wheel...guess it'll do for now... "
WHere was this information a few months ago when I replaced my turnsignal wiring harness for the second time because my horn contacts had worn down to nothing?
drfister
May 3, 2018 10:38 PM
Urambo Tauro
Dec 17, 2016 03:30 PM
squishbang
Dec 4, 2015 02:29 PM
kdryan
Aug 29, 2015 09:57 PM
Careless00045
Aug 29, 2015 10:44 AM
