FAQ on water pump
Old Jun 21, 2006 | 01:54 PM
68Midnight's Avatar
68Midnight
Default FAQ on water pump
Is there a write up on changing your water pump? Ill be doing this in an hour and help would be appreciated. Is it just unbolt old throw on new? Thanks.
-Nathen
Old Jun 21, 2006 | 03:13 PM
Gun Jam's Avatar
Gun Jam
Default RE: FAQ on water pump
Pretty much, there is a gasket that goes with the new one as well, take care to clean the old pieces of gasket off. Some type of gasket sealant may be used as well, Not sure what to recommend though
Gun
Old Jun 21, 2006 | 07:31 PM
ideal_mustangs's Avatar
ideal_mustangs
Its a pretty simple job. Don't bust the original FoMoCo radiator when you pull the fan off, I know form experience.
Old Jun 22, 2006 | 12:04 AM
mustanglover66's Avatar
mustanglover66
keep track of which bolt came out of which hole they are differnt lengths and can be a pain putting the new one on.
Old Jun 22, 2006 | 02:54 AM
289FB's Avatar
289FB
Nathen..it is a very simple job I am pretty sure everyone does it but I do remove the radiator for the replacement it is a few more minutes but give you much more room to work and it much easy to remove the fan and also is a good time to change the coolant , as for the gasket sealer I use Edelbrock Gasgacinch, clean the old gasket from the block apply the sealer on both surfaces and let them dry for about 5 minutes them place the gasket on the pump and bolt it on
Old Jun 22, 2006 | 10:26 AM
Soaring's Avatar
Soaring
I ♥ Acer
I use Blue RV for gasket goop. Just a very thin layer with the gasket will be sufficient. And, unless you have steel knuckles, taking out the radiator is the best advice anyone can give you.
jwog666
Dec 27, 2021 08:09 PM
jerrytubes
Oct 23, 2015 12:11 PM
Bokeo
Oct 10, 2015 08:28 PM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
