Front plate bracket opinions
Old Jun 25, 2006 | 06:42 PM
  #31
Clu7ch's Avatar
Clu7ch
Default RE: Front plate bracket opinions
ORIGINAL: Soaring
We keep using the word Bondo. That is a name brand for body filler. Don't body shops use a better filler brand than Bondo?
yeah. bondo's got a pinkish hue to it and the stuff the shops use is more of a sea foam green-ish
Old Jun 25, 2006 | 06:49 PM
  #32
Soaring's Avatar
Soaring
I ♥ Acer
OK, that looks like what John used.
Old Jun 25, 2006 | 06:53 PM
  #33
Clu7ch's Avatar
Clu7ch
i think it's just the fact that everyone knows what bondo is or maybe there's 2 types of bondo, the body filler he used and the pink one people think is a "cure".
it's just easier at this time to refer to it as bondo. [&:]
Old Jun 25, 2006 | 07:33 PM
  #34
slickman's Avatar
slickman
Its just the generic word everyone uses for plastic body filler.
ORIGINAL: Soaring
Old Jun 25, 2006 | 08:13 PM
  #35
67t5ponycoupe's Avatar
67t5ponycoupe
Bondo is brand name that everyone uses when they really mean plastic body filler. No I'm not using "Bondo" Brand Filler. It is the good quality stuff from the body shop supply store. The color of the filler is only due to the hardener that goes in the filler. Nothing to do with brand of filler. The two hardener colors are blue and red. Depending on how much, and what color hardener you put is is what color you end up with. I agree bondo in not a cure. You must use it to get a panel straight not build it up to create your own panel. If you have ever watched American Hotrod and seen how they do it you will know what I mean. They do the metal work then basically coat the entire car in bondo and work it down with long boards until it is perfectly straight. I don't see anyone complaining about the bondo they use. That is what ya gotta do to get these old buckets straight!
Old Jun 25, 2006 | 08:15 PM
  #36
Clu7ch's Avatar
Clu7ch
thank you for the body work lesson!
muchly appreciated!
Old Jun 25, 2006 | 08:34 PM
  #37
67t5ponycoupe
Sure! BTY, I just ran the totals on the car. I said I wouldn't until it is done but I really wanted to know. Looks like$ 18,000. Not as bad as I thought.
Lethaldosage423
Oct 19, 2015 12:12 AM
guitarman376
Oct 11, 2015 01:47 AM
Oct 7, 2015 07:02 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
maestro1024
Sep 21, 2015 02:40 PM
