cowl air flow?
Old Jun 26, 2006 | 07:25 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: cowl air flow?
ORIGINAL: Clu7ch
okay, thanks a million Glen. now, another question for ya. that box you have under your switches, with the four vents in them. can i buy one somewhere and how does it connect to the vent system?
That is the airconditoner condenser. In these old cars, it was inside, and you can move those vents to where you want the cool airconditoned air to go. If you don't have an airconditoner, you won't have those. Yes, you can add that if you want to. If you do, then chime back in.
Old Jun 26, 2006 | 07:27 PM
Clu7ch's Avatar
Clu7ch
ORIGINAL: Soaring
ORIGINAL: Clu7ch
definatly, i have been tossing the idea around for a while. i'm probably going to end up going with a 302 instead of a 351 so i can have a good cruiser with a/c.
Old Jun 26, 2006 | 07:29 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: atomsk680
ORIGINAL: Soaring
It is a rather crude and simple mechanical operation. The heater and defroster controls are named from left to right..... Heat-Temp-Def. If you have them all three in the up position, and the blower switch all the way to the left, it is not on. If you put the Heat **** all the way down, and the Temp all the way down, you will get maximim heat. If you raise the Temp up a tad, you will get less hot water running in the box, giving you less heat. If you put the Defrost know all the way down, you will channel all the hot air to the windshield via some flex hoses, and the air comes out the grid on the top of your dash on each side of the radio speaker. You can have both heat and defroster at the same time by putting those two ***** about halfway down. Now, you will not get air unless you turn on the fan motor by sliding the switch to the right. So, to answer the original posters query, you will not get air coming out of the defrost vents unless you have motor switch on. But, you can get fresh outside air out of the defroster vents if the motor is on. The other fresh air vent is next to your emergency brake handle. When you pull that out, you get fresh air through the cowl. See the pics.
[IMG]local://upfiles/10034/46109D0115A8419EAA65127FC560DA10.jpg[/IMG]
[IMG]local://upfiles/10034/21BAA0E3DA8143DD8FE4CEBF8DFFC9BF.jpg[/IMG]
your's are easy to figure out!
mines complicated.... i dont know where the "i just want a little air to blow in" area is.
Look around under the left of the steering wheel to see if you have a fresh air **** to pull out. Otherwise, I guess you just need to roll the windows down and sing a good country and western song while you are burning up. (or use the air conditioner)
Old Jun 26, 2006 | 09:16 PM
351foxstang's Avatar
351foxstang
thanks for the help,
i wasn't sure if air would still come in, like on a newer car.
daltron
Apr 28, 2016 08:10 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
Dokilar
15
Oct 16, 2015 08:13 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
1996cobraconvertible
SVT Forums
Sep 30, 2015 02:01 PM
