Water pump Q
Old Jul 13, 2006 | 05:33 AM
DogOnPot's Avatar
DogOnPot
Default Water pump Q
So, I'm trying to figure out if my water pump is bad. How exactly do I tell this? I do know that my car still heats up terribly, but I want to make sure it's not the thermostat or something on the fritz. Anyway, any help would be appreciated.
Old Jul 13, 2006 | 10:38 AM
Silver Ponys's Avatar
Silver Ponys
Default RE: Water pump Q
What makes most pumps go bad is the seals fail then antifreeze runs out the weep hole on the snout of the pump. If you open your rad and see the water circulating through it the pump is proably ok. If no water is circulating i would check the thermostat first. Take it out and put it in a pan of water heat the water and see if it opens.
Old Jul 13, 2006 | 07:13 PM
DogOnPot's Avatar
DogOnPot
I went to NAPA and they had several differant pumps available. Which am I looking for exactly? They all fit, but they nor I knows the differance. I'm assuming Gallon per minute, but I don't know for a fact. Thanks
Old Jul 13, 2006 | 07:28 PM
PX429's Avatar
PX429
i haven't read any of your old post. what have you replaced so far?
Old Jul 13, 2006 | 07:56 PM
DogOnPot's Avatar
DogOnPot
The belt.
Old Jul 13, 2006 | 10:32 PM
mustanglover66's Avatar
mustanglover66
The differcne in the pumps at NAPA probibly are Aluminum for 64 earily 65 cast iron stanhdard rotation and the reverse rotation for serpinten belts.
jwog666
Dec 27, 2021 08:09 PM
jerrytubes
Oct 23, 2015 12:11 PM
Bokeo
Oct 10, 2015 08:28 PM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
