Alternator Gauge ?
Old Jul 17, 2006 | 10:41 PM
DrBob67's Avatar
DrBob67
Default Alternator Gauge ?
Here is the basic story. 67 289 V8 with pertronix ignition. When I check the (stock) alternator guage, I notice that it kind of oscillates back and forth rythmically. It doesn't move back and forth very far just a few degrees. I moves from right around the midline position toward the C side, back and forth at a cycle of about once per second or maybe a little faster.
Now that I think of it I don't remeber trying to check it while I'm moving just when idling at a red light for example. Next time I drive it I'll try and check it while I'm in motion.
I don't know if this is normal or if it means anything. I'm just curious.
BTW the battery is about 2 months old and the alternator seems to work fine, the battery stays charged. But I have not actually tested it with a meter.
Any ideas or comments would be appreciated.
Old Jul 17, 2006 | 10:44 PM
DrBob67's Avatar
DrBob67
Default RE: Alternator Gauge ?
Just to make sure I am explaining it correctly. THe actual needle in the guage moves back and forth slightly from near the center position to slightly into the C side or right side.
Old Jul 17, 2006 | 10:47 PM
Soaring's Avatar
Soaring
I ♥ Acer
That's normal. "If it ain't broke, don't fix it."
Old Jul 17, 2006 | 11:07 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Count yourself lucky that you have one that moves at all. Most of them just sit there and so nothing.
Old Jul 17, 2006 | 11:32 PM
jdforsythe's Avatar
jdforsythe
Very frequently the coil inside of the guage will burn out. These can be replaced but it is a pain as you need to remove the guages. I agree with Soaring...just live with it, not that critical
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Golfsito
Oct 6, 2015 11:02 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
