torque boxes
Old Jul 25, 2006 | 01:00 AM
atomsk680's Avatar
atomsk680
Default RE: torque boxes
ORIGINAL: RES
So how much body work have you done this far? Have you swapped out the quarters yet and if so how much and were did you get them from?
as of right now, i dont need quarters, maybe a lower quarter patch on my passenger side, but my quarters are solid.
Old Jul 25, 2006 | 01:03 AM
RES's Avatar
RES
I've got the little bit of rust on the lower quarters also, but I think I'm just going to go ahead with the full quarter skins.
Old Jul 25, 2006 | 01:11 AM
atomsk680's Avatar
atomsk680
ORIGINAL: RES
mustangs plus has lower quarter panels for sale, not the full quarter but i am also considering one of these for myself instead of a patch.
Old Jul 25, 2006 | 01:38 AM
428coupe's Avatar
428coupe
Dont skimp out on the torque boxes, they should really help strengthen you chassis. If you have not done much fabricating, buy new ones, even if it sets you back some it will be worth it. Torque boxes, in my opinion, are not optional, especially since you are going to be running a v8
Old Jul 25, 2006 | 01:42 AM
atomsk680's Avatar
atomsk680
ORIGINAL: 428coupe
thanks, when i get to this point i will decide whether or not to buy or make.
Old Jul 25, 2006 | 01:32 PM
dodgestang's Avatar
dodgestang
T-boxes triangulate/support the rocker to the frame rails. They are an excellent test to determine your car's 'straghtness. If you make these boxes at home you will lose that benefit (the same goes for those that take them apart to install them). Getting the manufactured torque boxes is how you can determine within a small margin of error that your car is straight in the front. They are a tight fit and sometimes require force (I use the weight of the car to my advantage) to get in but once it, they are in.
Old Jul 26, 2006 | 12:12 PM
coda618's Avatar
coda618
+1 on the manufactured TB's. They are relatively inexpensive, and not worth the cost/benefit of doing it yourself. You will spend hours to make one and it will prob. not be as structurally sound. The shape and bends are engineered to withstand the specific stresses they will undergo. They are available for about fifty-sixty bucks. What is 5-10 hours of your time worth?
baddog671
Jul 26, 2016 01:20 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
daltron
Apr 28, 2016 08:10 PM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
