battery draining HELP!!
Old Jul 26, 2006 | 03:34 PM
  #21
KStang65's Avatar
KStang65
Default RE: battery draining HELP!!
I'm looking at the wiring diagram now and it looks like the only way the alternator connects to the battery on the positive side is through a post on the starter motor relay. The post on the alternator may have a label of bat but I'm not sure if it's an aftermarket alternator. The post should be the one facing the battery and connects directly to the + side of the battery.
You may want to check the ground coming off the alternator as well to make sure it's making good contact with the chassis as that's the other point of contact with the negative side of the battery system. The ground comes off the the ground post on the alternator and is spliced in with a cable running to the alternator regulator.
There are several wires that run into the car such as the fuse panel and ignition system. Have you checked the fuses?
Hope this helps.
  #22
option4130's Avatar
option4130
nope both alts have the same shape to it
Old Jul 26, 2006 | 03:36 PM
  #23
option4130's Avatar
option4130
i have not checked the fuses but thanks that does help im gonna go check on it........i will keep this udated thanks guys
Old Jul 26, 2006 | 03:37 PM
  #24
Gun Jam's Avatar
Gun Jam
dang it should work then
Okay i again second the multi meter its only 20-30 bucks and its good for lots of things im sure youll be glad you bought it
Good luck
Gun
Old Jul 26, 2006 | 04:22 PM
  #25
Soaring's Avatar
Soaring
I ♥ Acer
Not sure what year Mustang you have, but here is an alternator wiring diagram for the 65-66.
http://www.cjponyparts.com/TechAltWiring.asp
Old Jul 26, 2006 | 11:22 PM
  #26
option4130's Avatar
option4130
thanks i think my ground cable was connected to the sta instead of the ground post
Old Jul 26, 2006 | 11:26 PM
  #27
option4130's Avatar
option4130
If anybody else has any other ideas to why than please i could use all the help i could get
Old Jul 26, 2006 | 11:37 PM
  #28
Gun Jam's Avatar
Gun Jam
cool
Hope it works out
[edit] you did switch them right? Did you try the headlight test?
Gun
BOB ROME
Jul 26, 2023 01:54 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
jerrytubes
Oct 23, 2015 12:11 PM
wraith777
Sep 28, 2015 10:49 AM
logan409
Sep 26, 2015 07:43 PM
